rough running engine tonight after a solid day of rain
  • Miljack
    • Dec 2004
    • 1616
    • Charlotte, NC
    • '08 230 TE ZR6
    I went out this afternoon for quick set, and once I warmed up the boat, and began cruising to a riding spot, the boat sputtered out and died a couple of times. It actually was running about 2800-3200 rpm, and just sputtered out and died. It did it a couple of times.
    I noticed that there was a strong smell of raw gas, the boat would run in neutral at 2k rpm, but it was still trying to die. Then I just kept running at slower speed, and it cleared out.
    We did have a solid 1.5 days of rain here, and the boat did get wet inside despite the cover, and probably got some moisture in the engine compartment.
    The boat initially started instantly, and was idling pefectly out of the cove. Is it possible some water got into the distributor cap/and or spark plug wires?
    Btw, DD Pro Air python.
    thanks,
    Jack
    2008 230 TE-ZR6
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: rough running engine tonight after a solid day of rain
    Sounds to me like you had some water in the gas or something... I'm glad it got cleared up, whatever it was.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • richard
      • Feb 2005
      • 406
      • HK
      engine running rough
      I'll start from checking all the spark plugs for wet.
      • MNSuperAir
        • Sep 2005
        • 591
        • St Paul
        • 2016 SAN 210
        RE: engine running rough
        Not sure what model you have but I assume it is carburated. Probably some moisture in the distributor or plugs/wires.
        2016 SAN 210
        2006 SANTE sold
        2001 SAN - sold
        1991 Sport Nautique - sold
        • surroundsound64
          • Jul 2005
          • 2147
          • Longview, TX
          I think if there was moisture in the dist. it would have given him problems when he tried to start it up.
          2018 SAN 230
          1981 Ski Nautique
          Sold - 2000 SAN
          • Miljack
            • Dec 2004
            • 1616
            • Charlotte, NC
            • '08 230 TE ZR6
            An update, not a problem since I first posted...I'll mark it down to the ton of rain that came through. We ran it for about 4 hours over the weekend, no probs.
            thanks for the replies.
            Jack
            2008 230 TE-ZR6
            • Zwengit
              • Mar 2006
              • 42
              • Costa Mesa, CA
              I'll bet it was wet plugs/wires . . . should check it out in off season so it doesn't happen the next time !
