Hi all,
I’m changing my fluids for my first full season. I noticed the V Drive has pink apparently trans fluid in it. I know the Walters recommends 30W which is what I have.
I just wanted to verify there’s no way the transmission and the V Drive could be sharing the same trans fluid for some reason?
I’m draining the V Drive now with an extractor and I will add the SAE 30 back in.
I just wanted to ask if there was some weird set up where they might both be using shared trans fluid at the same time.
