2018 G23 ballast can be drained till the screen reads 0lbs but when you turn the boat and battery off then back on the starboard side always has weight in it. I have reason to believe the STBD side is still holding water because the boat leans to that side when still and on pad. The wake is even bigger on that side when the ballast screen reads all empty. Is there a way to recalibrate the ballast system without going back to dealer?
