I have a 1990 SN with 351 W and would like a 4 blade prop to perform similar to the standard 3 blade, but better! Suggestions?
You can search on the pros and cons of 3 vs 4 bladed props. Lots of information here and on ballofspay.com on that topic.
Wakemakers.com has a nice prop selection tool you can use to pick choices for your boat.
https://www.wakemakers.com/props/2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
You might also try an OJ SkiPro. You'd need to call them to find the best fit, but they can set you up right.
https://www.ojprops.com/products/skipro/I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Aug 2014
- 380
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
Assuming that you have a standard LH rotation engine and PCM 1.23:1 transmission, then I would lean toward the ACME 654. If you are a RH engine with 1:1 Velvet, then I would call ACME.
JQLast edited by Jonny Quest; 05-26-2021, 09:37 AM.
