1976 SN: 351 Firing Order
  • Hydrofoilmaniac
    • Apr 2006
    • 105
    • Menomonie, WI
    I have a 351 in my 76. It's LH rotation.
    Does anyone know what the firing order should be? I believe it should be 1-8-4-5-6-2-7-3 (clockwise). Is that correct?
    Also, is the #1 cylinder for a ford the front starboard (driver side) cylinder?
    Sounds like stupid questions.....but sometimes you just got to ask anyway.
    1976 Ski Nautique.....old but it\'s still going strong
  • TRBenj
    • 1681
    • NWCT
    RE: 1976 SN: 351 Firing Order
    Yes, the #1 cylinder is the forewardmost cylinder on the starboard side. The firing order you have is correct for a RH (reverse rotation) 351w. If the motor in your '76 is original, then that is the correct firing order. If it has been replaced with a standard rotation (LH) motor, then the correct firing order is 1-3-7-2-6-5-4-8.
    1990 Ski Nautique
    NWCT
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      The firing order should also be written on the engine plate on top of the engine block on one side or the other of the carb. The cylinder numbers should also be stamped into the top of the block.
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
      • Hydrofoilmaniac
        • Apr 2006
        • 105
        • Menomonie, WI
        Thanks. I noticed the engine plate tag after I had posted the note.
