Well apparently I found the cheapest way in the world to get a zero hour boat. I had to replace the 4 in 1 (or however many in 1) gauge that has the tack and hour meter in it. After replacement my hours are now set to zero. I thought the ECU set the hour meter and the correct hours would be displayed after the replacement. Apparently I was wrong (there I go thinking again). Is there any way to set the new hour meter to what the ECU would reflect or is this something I have to document and live with? Of course I didn't write down the hours from the old meter but since I didn't toss it is there a way to power up the gauge and get the hours off it?
OK Jeff, Charles and bunch of you other guys that really know these boats, I'm expecting greatness from you guys again.....
