Dead Battery....Keylesss Ignition Issues...04 SV-211
  • oldskier
    • Jun 2006
    • 8
    Can anyone guide me in my quest to start my boat. I had a prop replaced 2 weeks ago the auxillary power (single light) was left on by the dealer after the prop test. Now my battery is dead.
    I now have both a portable jump and a second battery (since I have room for 2). I have hooked everything up correctly...no power (or more correctly the single light does not come on after I put in my code which is not the original.)
    I think my issue is that I don't know the original code to the keyless ignition and the code I programmed in is now lost. Would this cause the problem? How should I get the original code?
    Any help would be appreciated.
    mb
  • jmo
    • Mar 2006
    • 710
    • MA
    If you flip the kill switch to "Bilge only" the light next to it should light up regardless of the keycode. If it doesn't, you probably have a loose connection somewhere since you have already tried the battery.
    I had something similiar happen - trailered up for a week on Moose Pond in Maine, go to launch for the week and the boat is completely dead. I figured out the next morning that one of the connections to the On/Off/Bilge only switch popped off - because the dealer didn;t secure the kick panel (both screws on the left side weren't fastened - arrghh!) in the spring after installing a heater - and hence after trailering 150 miles with the panel vibrating back and forth it pulled one of the connections loose.
    Hope this helps
    2018 Ski Nautique 200 TE, H6
    • jmo
      • Mar 2006
      • 710
      • MA
      Also, if the kill switch is in the "on" position and you touch the keypad it should activate the background lighting on the pad, if it doesn't - you've got a bad connection somewhere.
      • SGY
        • 990
        You can get the master code from your dealer or the factory. Also check your manual, sometimes it's written in there.
        • Brownie
          • Jun 2004
          • 87
          • Nowra/Taree NSW, Australia
          the toggle switch can get a bit corroded and play a bit of havoc with connections. This happened on my 03 and 04.
          • oldskier
            • Jun 2006
            • 8
            All set....Thanks for the advice. I called my local dealer and was able to get the original code.
            thx
