Hi all, I'm a newbie here, I’m hoping that someone out there can help with a perplexing ignition problem. I have a key actuated ignition that does not activate the starter relay, but it is an intermittent problem, most of the time it is broken. I have chased this the best way I can without a schematic. First of all, does anyone have a good one, all the ones I’ve searched for are not detailed enough.
So back to the problem, I’ve checked and done the following…
The problem seems vibration induced, but I can’t recreate it by shaking harnesses or reseating connectors. An example of what I’m talking about, boat died at the dock, towed it to the launch ramp, pulled it out and drove back to my garage about ¼ mile away, the darn thing started! The next day, hooked a hose to the boat, started it, ran it for 15 minutes, towed it 200 yards to the gas pump, it died again.
Need some ideas on where to check other voltage points, I think it is a continuity problem or does the ECM come into play for the starter circuit?
I appreciate any help!
Bruce
- Replace the ignition switch.
- Replaced the PME relay under the dash.
- Hard bypassed the lanyard switch.
- Hard bypassed the neutral lockout.
- Validated operation and contact closures of the starter relay.
- Validated operation of the ignition relay, rolled it with the fuel pump relay since they are the same.
- Checked the voltages on Starter Relay, appears I’m not getting a ground to activate, 12v appears on one side of the relay coil.
Bruce
