Noticed the last time out that my temperature gauge wasn't working. Not only was the gauge itself not working, but the light the temperature gauge wasn't coming on, while all other gauges and lights were working.
This leads me to believe that it's an electrical issue, but I am not sure where to start to troubleshoot. Any ideas?
As a side note, I did deal with some overheating related issues my first few times out this year. Long story short, the dealer forgot to put the o-ring back on my water strainer causing the boat to overheat. When I realized this was the issue, they offered to replace any affected components. They ended up only replacing the impeller and saying that the overheating was actually more likely due to low coolant levels, which they topped off. No engine overheating alarms have happened since then.
Thanks in advance!
Thanks in advance!
