2000 super air Nautique prop for wakesurfing
  • LiamJ
    • May 2018
    • 6
    • CA
    • 2000 SAN
    Hi I'm trying to find the ideal prop for wakesurfing. I'm at 6200ft and running 2500-2800#s of ballast. I called acme and they are recommending the acme 420 for my situation. I just haven't seen this prop mention in any other threads on this topic. Also a little skeptical because the blade size is smaller than the other prop suggestions that get tossed around on here
    2000 SAN
  • XBIGPUN66
    • Oct 2012
    • 460
    • Lake Mendota
    • WI
    I think we used the 1433 or 1435 on our 2004 210
    Ian S
    2014 SANTE Reef Blue/ Black metal flake. NSS. Pro balllast. Boatmate trailer
    2004 SANTE Masters Blue. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
    2009 Moomba Outback Red(prev). Boatmate trailer
    • LiamJ
      • May 2018
      • 6
      • CA
      • 2000 SAN
      I'm a right hand rotation so from what I understand I have to get the even numbered props, I'll check out dimensions of those props and see if they have a rh equivalent thanks
      • hal2814
        • Jun 2016
        • 542
        • Ft Worth, TX
        ACME's recommendations are usually spot on. I'd ask them their reasoning. They'll tell you. Seems really low diameter to me. I ran an ACME 1234 on my 95 Super Sport with the same hull. That's a 1.5" larger diameter prop. I wonder if they're having you go smaller in diameter because you may be lugging the engine at altitude with anything larger?
        • LiamJ
          • May 2018
          • 6
          • CA
          • 2000 SAN
          Yeah they said they don't make a 12.5 pitch in the 13.5" diameter prop so I think they're assuming I can't got bigger? I just sent an email asking about going to a 14". I wish I knew what prop I had right now but she's in the water and it's a little hard to get the numbers. She does alright out of the hole Im just getting so much prop wash on the port side it's hard to get a clean wave with my shaper. I'm hoping a prop that doesn't have to work as hard helps, also my current prop has a few nicks in it
          • bturner
            • Jun 2019
            • 1631
            • MI
            • 2016 200 Sport Nautique
            Try OJ, I've had very good results with their recommendations and service.
            • msquito
              • Jun 2020
              • 88
              • WA
              • 2000 Super Air Nautique
              Just put an ACME 1578 on our 2000 SAN this season. Very happy, big difference. Lost a little top end, but still plenty of go for us and it gets out of the hole and takes turns (with a tube) much better.
              • LiamJ
                • May 2018
                • 6
                • CA
                • 2000 SAN
                Yeah I'm probably going to go with the 1578. I'm going to pull the boat out of the water in a few days and make sure it's not the one I already have. If it is the one I already have I'll go with something different. I'll give an update once I have the new prop installed and running serious ballast weight
                • CLSurfer
                  • Mar 2022
                  • 3
                  • North Vancoiuver
                  • 1995 Nautique Super Sport
                  Hey, we've got a new to us '95 SS, just kitting it out now, will be at 1460ft. We have 2 - 500lb bags for the rear, may upgrade to 800's. And thinking of doing 300 in the bow.
                  Mostly surfing, some tubing (but don't really care about that performance), some slalom, and not much cruising.
                  Wake Makers recommends:
                  856 - Recreational/Everything
                  644 - WakeBoard/WakeSurf
                  1578 - HighElevation/Heavily Weighted
                  What are your thoughts?
                  • LiamJ
                    • May 2018
                    • 6
                    • CA
                    • 2000 SAN
                    I went from an acme 644 to an acme 1578. Running 3000lbs at 6000ft the 1578 gets me out the hole no problem but I definitely lost mph off the top. Running less weight (2000lbs) at elevation the 644 definitely did the job
                    • hal2814
                      • Jun 2016
                      • 542
                      • Ft Worth, TX
                      As I stated above I went with an acme 1234 on my 95 Super Sport running similar weight to what you’re looking at. It’s not Wakemakers suggestion but Wakemakers lumps all SS/pre-2006 SAN together. The hull is the same. But either due to shaft length or engine position the older Super Sports have about a full inch more clearance so they can accommodate a larger prop. The ACME 1234 is the same pitch and cup as the 1578. It’s just a larger diameter.
