Any one know how one is to adjust the friction on the wake/hydro gate plate? If I put it up to Surf (forward), over about 10 seconds (while driving) it will slide back into the wake position.
Do you tighten the front or the rear lock nuts on the pivot (plate connected to push rod at top and wake plate at bottom)? Do you tighten the forward lock nuts (connecting previously described pivot plate with the actual wake plate)?
Is there a friction adjustment somewhere else?
Thanks for the help!
