Bilge pump testing? 2016 SAN 210
  • FoodClub
    • Jun 2021
    • 29
    • OH
    • 2016 SAN 210
    Do other people test their bilge pumps? Of so, how do you do it?
  • jhiestand
    • 778
    • Columbus, Ohio
    • 08 Super Air 210
    I thought my stern pump wasn't working so I disconnected it from it's base (easy to do, twist and pull) and found the base has mesh wire that was just clogged. Since the pump was loose and I could hold it in my hand, I activated the pump switch (it hummed/spun) and then put it in a bucket of water where it proceeded to pump water furiously. Another test is to insure your plug in and just dump some water in the bilge.
    My forward pump was a bear to get to so I just insured I could hear it running. I think the dumping water in the bilge would work for testing it, as well. Obviously, you'd only do that on a trailer or lift!
    But yes, not a bad idea at all to test pumps.
    '08 Super Air Nautique 210
    • MN Ryan
      • Aug 2020
      • 1250
      • Maple Grove, MN
      • 2007 SV-211 TE
      I listen for them to turn on, but I guess I just trust that they'll actually pump water.
      Should be as simple as putting water in the bilge (hose or buckets) and making sure they work. Or, if you're on a lift or trailer, get the boat low enough in the water and pull the plug.
      • MN Ryan
        • Aug 2020
        • 1250
        • Maple Grove, MN
        • 2007 SV-211 TE
        The only thing you could be missing there is if there is a blockage or kink in the outlet hose.
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Yes. A couple of times a summer I use some car wash and a brush to scrub the Sea Dek clean. I intentionally leave the plug in the boat. The soapy water makes it's way to the bilge and the pumps push it out. This does two things:
          - Verifies that the pumps are working properly.
          - Pushes some soapy water through the pump, hoses, etc. to give them a cleaning.
