Check Display to Display Cable Error
  • Renegrub
    • Jun 2021
    • 21
    • Grand Lake, OK
    • Leawood, KS
    • 2022 Nautique Paragon G23 2024 Chris Craft Catalina 30 2021 Sea Ray SLX 400
    Anyone else have the same issue on a 2020+ G23 Paragon? I recently purchased a used 2020 G23 Paragon. At delivery an error message displayed on the left screen, “Check Display to Display Cable”. The left hand screen did not display depth, outside temp, water temp or accurately sync speed limit. When you start the boat - sometimes the error goes away - but when you drive in choppy water it triggers the error and it persists for some time. It can go away and come back. Very annoying!
    The dealer mechanic opened up the compartment below the displays and zip tied the right hand end of the cable in the connector. He couldn’t get to the left hand side without a multi-hour removal of part of the dash. It looked like it corrected the issue but once you go out in choppy water the error comes back up.
    I am taking the boat back to the dealer tomorrow for them to hopefully get it fixed, but I don’t have a ton of confidence in the thoroughness of their approach. Boat only has 60 hours on it.
    I am hoping someone else has had this issue and knows precisely how to resolve so I can give this feedback to the dealer. To me, this feels like a cable receptacle issue - one end of the cable is not staying seated in the port. I have a hard time believing the solution is to zip tie it to the port. It could be the cable but doesn’t make sense to me - cables are pretty simple - the movement triggering the issue feels like a port issue. A bigger issue could be wiring in the receptacle on one of the ends that is loose.
    I would appreciate any guidance so I can hopefully ensure the problem is resolved the next time.
    Picture attached as well!
  • bird_dog0347
    • Oct 2020
    • 352
    • DFW
    • 2021 G23 Paragon
    We only have 17 hours on ours so not sure if it will happen but hasn't yet. I've seen at least one other person post either on here or Facebook, don't recall, that had the same issue. Since you bought it used, did you do the warranty transfer? If so, I'd let the dealer take care of it with the multi-hour labor they mentioned.
    • mikenbike211
      • Sep 2016
      • 447
      • New York
      • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
      On the back of the displays is a single cable with a silver metel collar that needs to be fully screwed in /seated. The buss plug he zip tied is the wrong cable. This cable needs to be checked on the back of both displays.
      • shag
        • 2217
        Wow, a 1/4 million dollar boat and they are zip tying things to 'fix' a problem?
