Auto equivalent to Excalibur 330?
  • jwhopson
    • Jul 2015
    • 8
    • McMinnville, OR
    • 2004 SAN 210 LE/TE
    I have a knock sensor that I want to replace and I have a 2004 Super Air, Excalibur 330 PCM engine which I think is similar to a GM something engine. Does anyone know? Thank you in advance.
  • SatherG230
    • May 2018
    • 83
    • MN
    • 2012 SANTE 230 w/ NSS
    I've never had an Excalubur 330, but I believe its a 5.7 liter GM 350 small block.
    • SilentSeven
      • Feb 2014
      • 1866
      • Bellevue WA
      • 2004 Nautique 206
      If no one has a better answer, I've had past luck pulling the part in question and using any stamping numbers to ask NAPA or similar to look up the part number. Once they find the part, they can cross it back to car models with that engine which then gives you a pretty good starting point to locate other parts.
      Bellevue WA
      • jmo
        • Mar 2006
        • 710
        • MA
        Did you look on nautiqueparts.com? They should have it.
        2018 Ski Nautique 200 TE, H6
        • Iamwildbill
          • Jun 2020
          • 22
          • Texas
          • 2004 super sport 210
          Do t know if you’ve already found or not…. But it should be a 98 Chevrolet Silverado 1500. That’s what worked for me at oreillys.
          • jwhopson
            • Jul 2015
            • 8
            • McMinnville, OR
            Nautique Team, thank you so much - I was able to get one at the local napa store - thank you for the suggestions!
