no throttle but it goes in gear/reverse
  • Mlagrone
    • Sep 2014
    • 18
    • Danville ca
    • 2006 SANTE 220
    I was driving my 2006 SANTE 220 today and I have had zero problems with the boat in the last 12 years I have owned the boat.
    Today I was leaving the launch ramp area, put the boat in gear all is good. The moment I tried to go, I had not throttle. It was like the cable came disconnected or something. I checked that all was good. It would go into reverse and forward only at idle speeds it engaged (no gas) almost like the perfect pass took control. I then turned off the ignition then back back on and the issue went away, (for a while) this happened intermittently thorough the day. I was driving then it happened, turned it off/back on it went away. no clue how to trouble shoot this!! now I am afraid to take the boat out... any advice ? help needed.
  • James
    • May 2007
    • 151
    • Indian Wells, CA
    It sounds like your potentiometer (throttle position sensor) is failing.
    • Mlagrone
      • Sep 2014
      • 18
      • Danville ca
      • 2006 SANTE 220
      That Makes sence, where will I find a TPS for a 2006 PCM ZR6?
      • James
        • May 2007
        • 151
        • Indian Wells, CA
        NautiqueParts.com (use PND for the discount code and get 10% off) or Discount Inboard Marine
        • casmith71
          • Mar 2015
          • 24
          • Dothan, AL
          • 2006 220 SANTE
          did the TPS resolve the issue? i had a similar issue yesterday and after a total boat reboot it worked fine for a little while then started again.
