Excessive bilge pump running
  • Mahnal
    • Apr 2019
    • 92
    • Bowling Green, KY
    • 2014 SAN G25 - 550
    Last summer, we had an incident that required some hull repairs, a new prop, a new shaft, and some fittings around the shaft to our 2014 G25. Since then everything has been pretty good, and the boat appears to be water-tight. However, when we are running, the bilge pump (rear) runs more frequently than I remember. Note, this is only an issue while the boat is running / motor running. I left the boat in the water overnight (checked it every few hours), and there was no buildup of water. We see no abnormal build-up of water around the front bilge pump (next to the t-plug, ballast, and freshwater through-hulls).
    The bilge pump keeps up with the suspected leak. The bilge pump once ran for over 1 minute straight after I stopped. However, typically, it will run for 10-15 seconds and then stop for probably more than 15 minutes. If we are just floating, it might run for a few seconds when we stop, then nothing for the entire time we are stopped, or only after people get on the boat wet, and then it is expected.
    I have two bilge pumps, however, if for some the bilge continues to runs again, or both starts running, I will cut the engine, close the valves while the bilge catches up. So I think that is a good safety process, for the worst-case scenario, but I am still a little concerned.
    I think there are two possibilities: 1) There is a small leak in the fresh water cooling system or 2) there is a leak around the prop shaft stuffing box, that only shows up once the shaft is moving and it is heated up some and expands.
    Any suggestions?
  • Nautiquehunter
    • Jun 2008
    • 2080
    Can you run it on the trailer with a hose and look for water . That will eliminate the engine cooling system . Then put it back in the water and look at rudder and shaft.
