1995 SN Throttle Cable Change
  • Indygreen
    • Feb 2018
    • 56
    • Indiana
    • 2008 Super Air Nautique 230
    Just replaced the throttle cable on 95 SN. Everything works as it should but when I put it in gear and give it a little throttle it won't hold and wants to retract back. If I give it more throttle the lever will stay but when just wanting a little it springs back. I assume it's an adjustment but wanted to make sure I'm not missing anything. The previous cable did not do this. I don't believe I have any kinks or sharp bends, actually the new cable path is spot on with the old cable path. Any suggestions? Thanks
  • rkilcoyne
    • Apr 2018
    • 19
    • Clarksville, MD
    • 1995 Ski Nautique Signature Edition
    Mine did the same. I just unlatched the throttle spring back at the engine.
    Problem pretty much fixed.
    I then installed a hydrophase speed control to maintain speed. Now I just get going, set speed and use free hand for beverage management.
    Problem solved.
