Charging voltage?
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    Charging voltage?
    Had to jump the boat unexpectedly when departing the tie up today. Noted the charging voltage was 14.0 volts or less when driving the boat in on plane and closer to 12.0- 12.5 volts when driving at idle. In my auto experience anything less than 14.4 volts means the alternator is going out. Any opinions? 2014 210 with 5.7.
    Ian S
    2014 SANTE. NSS. Pro balllast. Boatmate trailer
    2004 SANTE. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
    2009 Moomba Outback (prev). Boatmate trailer
  • Mahnal
    • Apr 2019
    • 92
    • Bowling Green, KY
    • 2014 SAN G25 - 550
    I see the same voltages, and have for a while, so I am not sure that would indicate a failing alternator
    • nohlan_4
      • Jan 2016
      • 413
      • Canada
      • 2013 G23 450
      Could be a failing vreg. But i usually run 14.1V while surfing. Depends on how much load your taking on with accessory circuits and stereo. Lots of factors for that. I sit at like 13.7 at idle.
      • shag
        • 2217
        You mention you had to jump the boat when leaving tie up... Maybe any length of time could have ran batteries down some and at idle with other draws, maybe the alternator/boat was struggling for a short time to recharge? Also, a loose/worn belt can cause that... Just my .02
        • Nautiquehunter
          • Jun 2008
          • 2080
          Do you have any accessory's on
          • XBIGPUN66
            • Oct 2012
            • 456
            • WI
            I am trying to determine if I may have left the blower on. We did not play the stereo. I am not sure.
            Ian S
