Tower latch won’t pull back
  • Nautiqueusername
    • Aug 2017
    • 62
    • MN
    • 89 prostar 2020 230
    My right side latch that pulls and rotates to unlock will not slide back without major force
    anyone else experienced this? Any solutions? Does it require some sort of lube?
  • MikeC
    • Apr 2007
    • 535
    • Georgia
    • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
    The latch is adjustable. When the tower is down you can see the adjustment screw. You can try pulling back on the tower when you're trying to unlatch it to take the pressure off the latching pin.
    • Nautiqueusername
      • Aug 2017
      • 62
      • MN
      Not finding it
      very jammed up and now the nut is loose
      • Nautiqueusername
        • Aug 2017
        • 62
        • MN
        Yes I’ve been pulling back on tower to relieve pressure but to no avail
        what does this adjustment screw look like?
        • aromeo
          • Jul 2019
          • 68
          • WI
          • 2002 Ski Nautique w/GT40 2018 Super Air 210
          That large nut in the middle should not be turning. Those two allen bolts come off too, take them out and look at how it works. I had to take mine apart a while back because it was getting stuck.. After I fixed it I realized that pulling the lever completely out and maintaining outward pressure while turning prevents this from happening in the future. Haven't had an issue since I took it apart and fixed it.
