Prop Guard Wheels
  • OKWAKEBDR
    • 750
    • Lakefront
    • 2017 Super Air Nautique G23
    Prop Guard Wheels
    I have an '05 210 TE with a Dorsey double axle trailer. I have a pretty bad problem with the prop guard scraping the ground. If I use a lower ball on my truck, then the trailer hits the ground near the spare tire mount. I was hoping to get soem prop guard rollers, or wheels, or something, but all Dorsey offers is the kind that must be welded on. I would like to find something that I can simply bolt on myself. (i.e. drill a couple of holes and bolt them on). Anyone have any suggestions?
    Current: 2017 G23
    RE: Prop Guard Wheels
    Larger tires, or find a trailer or welding/fabricating shop in OKC
    • Flux
      • 408
      • Palmdale, Ca.
      Check these out:
      http://www.dhmtrailers.com/online/home.php?cat=161
      Guys at DHM are very good, call em if you got questions. The mounts might be the wrong angle for your prop cage, but could work anyway.
      • Grant_West
        • 758
        • Redwoodcity Ca
        I added the prop cage roller wheels (catstor style) to my trailer. I still have the orignal stainless steel cage rollers and they seem to hit first before the caster style wheels do. I guess when you trun real sharp the castor style wheels work real well. But when you back straight up the stainless steel rollers hit
        • OKWAKEBDR
          • 750
          • Lakefront
          That's exactly what I'm looking for, except I'd prefer something that bolts on. I may be able to go with the dhm rollers to mine, but I will have to have the mount modified (my prop cage is on a 90 degree angle).
          Thanks guys.
          Current: 2017 G23
          • Grant_West
            • 758
            • Redwoodcity Ca
            DHM has Weld on AND bolt on castor wheels
            • wake_fun
              • 1330
              • CA
              • 1995 Super Sport
              hhhmmmmmm, those look familiar :mrgreen:
              Photo Album
              Ballast Install 1
              Ballast Install 2
              Amp Install
              PPass Install
              Alternator Install
              • east tx skier
                • 1561
                • Tyler, TX
                I got a pair of these marine rollers for my boat. They are the weld-on type, but they also make bolt-on rollers. Having them welded on with angle brackets was very inexpensive.
                • Andrew
                  • Aug 2005
                  • 891
                  • Tuscaloosa, AL
                  buy some weld-ons, drill a couple of holes through the mounts and run a bolt though them
                  • causewayskiier
                    • Mar 2006
                    • 101
                    I had the same problem and tried rollers on the back of my trailer, but when you make a sharp turn, the rollers dont roll well and scrape the pavement. I ended up getting my trailer altered by pulling a 3 inch block between my axle and leaf springs. This lifted the trailer up, gave me more prop guard clearance and more clearance betweeen tires and wheel well. Worked well for me.
                    • OKWAKEBDR
                      • 750
                      • Lakefront
                      Unfortunately, that's not really an option...if my trailer were any taller, my boat wouldn't fit under the garage door.
                      Current: 2017 G23
                      • east tx skier
                        • 1561
                        • Tyler, TX
                        Feeling dumb. Didn't give you a link, a picture or anything in my post above. Just in case you're still looking.
                        I also did a lift on my trailer. About 2". I want my drag wheels to see use, but not on the driveway as they will shred it. Unfortunately, packtron doesn't make poly rollers.
                        http://www.pakindustries.com/
                        Here's the drag wheels right after the trailer refurb before the final coat of paint.
