I have replaced the impeller, thermostat, circulating water pump and i still do not have raw water flow. i took the thermostat out and the strainer does not refill. i put a garden hose in the hose after the water strainer and a little water is flowing. i am at a loss to what the issue is. any help would be appreciated.
Did you switch hoses? Which engine do you have? Crank driven water pumps on GM based engines are easy to switch.
Do you have to prime the water flow by filling the strainer, and hoses prior to hooking up, do i need to move the boat around to get things flowing. I have been dropping the lift and watching the temp without moving the boat around.
Should self prime but hoses have to be tight and strainer has to have a good o-ring seal. If pump is sucking air it won’t prime either.
I switched my hoses last year and it took me a few tries to figure it out. I had an old pic that saved me.
Start from the beginning.
1) which engine
2) which water pump (crank Johnson or accessory Sherwood)?
3) strainer with no bubbles
4) hoses all tight.
5) pump sucking air or worn shaft seal?
6) seacock open?
Just a few ideas there. You’ll get it.
We did a lot of trouble shooting over the weekend. when run the boat above idle, stays cool. when idling she slowly heats up. we took a hose and put water in after the strainer when idling - stayed cool. before the strainer did not. could the strainer be the issue? That doesn't make sense to me.
Are you missing the O ring for the strainer bowl? That's a common problem, and it allows the cooling system to suck air.
https://www.nautiqueparts.com/produc...rainer-gasket/I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
