GM 350 Vortek Rebuild Kit for PCM 330
  • CA_Nautique206
    • Jul 2021
    • 3
    • CA
    • 2004 Ski Nautique 206
    I am looking for a rebuild kit for a 2004 PCM 330 Excalibur engine. There are multiple kits available for a 350 GM SBC at significantly less than those labeled "Marine" 350 GM Vortek. From what I can gather, the only difference in the kits is the Marine gasket set and the freeze plugs are brass for the Marine kit. To my understanding, the piston is the same and the cylinder head is the same if purchased for the equivalent of a 99 Chevy Tahoe. Has anyone used a 99 Chevy Tahoe kit just the same and is there something I am missing about the difference in kits? ie rocker arms, piston rods, timing, etc.
    I did search for other threads and found similar but not exact question
  • Skidave
    • 697
    • York, PA
    Why are you rebuilding? Did something fail internally? Theses engines can go forever with minimal issues.
    Call Discount Inboard Marine. They will have the best answers for you.
    Sent from my SM-J337V using Tapatalk
    • CA_Nautique206
      • Jul 2021
      • 3
      • CA
      Would argue with the forever part with 3200 hours and multiple tows off the lake
      • MN Ryan
        • Aug 2020
        • 1250
        • Maple Grove, MN
        • 2007 SV-211 TE
        3200 hours?!?! Wow! In MN, most people think 1000 is too many.
        Sorry, but I don't have an answer for you.
        • Skidave
          • 697
          • York, PA
          That is a lot of hours. What types of breakdowns have you experienced? My guess is with that many hours, you went through many fuel pumps, caps, rotors and plugs. Rebuilding bottom and top ends will freshen up the motor, but you still have to think about all the other attached items that make the engine run.
          • Skidave
            • 697
            • York, PA
            • SilentSeven
              • Feb 2014
              • 1854
              • Bellevue WA
              • 2004 Nautique 206
              +1 for 3200 hours.
              Bellevue WA
              • CA_Nautique206
                • Jul 2021
                • 3
                • CA
                Update from another mechanic
                have worked on engines all of my life.......from machine shop owner to auto shop owner....the only difference is they use the factory hi performance four bolt block with the big valve heads...they do use a different cam/head gaskets/and freeze plugs....all other accessory's will bolt right on
                • aromeo
                  • Jul 2019
                  • 68
                  • WI
                  • 2002 Ski Nautique w/GT40 2018 Super Air 210
                  ****! that is a lot of hours. Please tell us more, is this a show ski boat or what?
