I am looking for a rebuild kit for a 2004 PCM 330 Excalibur engine. There are multiple kits available for a 350 GM SBC at significantly less than those labeled "Marine" 350 GM Vortek. From what I can gather, the only difference in the kits is the Marine gasket set and the freeze plugs are brass for the Marine kit. To my understanding, the piston is the same and the cylinder head is the same if purchased for the equivalent of a 99 Chevy Tahoe. Has anyone used a 99 Chevy Tahoe kit just the same and is there something I am missing about the difference in kits? ie rocker arms, piston rods, timing, etc.
I did search for other threads and found similar but not exact question
