PCM ZR6 : failing oil sending unit / switch can cause engine won't start ?
  • Hexa73
    • Aug 2015
    • 42
    • France, Savoie
    • CORRECT CRAFT SANTE 230 08'
    Hi guys
    I was wondering if a defect in the oil pressure sending unit or oii switch cause the ignition to fail and prevent the engine from starting ? I've a PCM ZR6 390 on a SAN 230 2008.
  • Nautiquehunter
    • Jun 2008
    • 2080
    On the GM trucks the oil sender also feeds the fuel pump . So no oil pressure no fuel pump no start.
    • Hexa73
      • Aug 2015
      • 42
      • France, Savoie
      well, that would explain why the engine doesn't start and there's no smell of gas even after several attempts to start (I already tested the FCC, no problem)
