2002 sante rear locker switches not working
  • 2002sansac
    • Jul 2009
    • 37
    The switches (all 4), do not operate to engage the electrical actuators to release the catch that allows opening of the locker. Seems like there is no power to pull in the relays. Anybody have experience in solving this issue? I would think that +12vdc should be present at the switches? Just an educated guess. Since all 4 switches are effected, it could be a resettable circuit breaker issue, but not so sure. I cannot locate a schematic illustrating the locker switches and actuator circuit.
    could use some help?
    Dave
    sacramento, CA
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    I would check the solenoids first. should be pretty easy to pull the connector off the solenoid and run 12 volts to it to make sure that at least the solenoids work.
    • 2002sansac
      • Jul 2009
      • 37
      Good suggestion. I’m figuring that since all 4 of the switches are not operating, that there is a general power supply (+12vdc) issue to the switches. As I’m mentioned, I’m cannot locate a schematic to follow, so I will just start checking for dc voltage at various locations…and visually look for disconnected wires, etc.
      thanks!
