89 balist resistor needed
  • H2Oboomer
    • Jul 2021
    • 10
    • Claytor Lake
    • 1989 2001 Ski Nautique
    My 89 balist resistor failed and the new replacement does n't
    work. So Im looking for either a working used one or how
    to switch to electronic ignition that doesn't need a resistor.
  • Jonny Quest
    • Aug 2014
    • 384
    Why don't you make the swap to an HEI unit like a Davis Unified Ignition (DUI) distributor from PerformanceDistributors.com? The HEI has the coil built-in and no external ballast resistor is required. Your engine will thank you for it. With a PLD engine, you can get a standard rotation unit and save a few shekels in the process.
    • H2Oboomer
      • Jul 2021
      • 10
      • Claytor Lake
      Thanks. Ill check into it.
      • hal2814
        • Jun 2016
        • 541
        • Ft Worth, TX
        DUI is legit. You can also get a Mallory marine distributor that will mostly just drop in. Coil isn’t integrated but you could then just buy one that doesn’t need it. But that’s all a lot of money just to avoid finding a $10 resistor. Have you put a multimeter on it to confirm the issue is the resistor? It’s really unlikely a new resistor would fail.
        • Nautiquehunter
          • Jun 2008
          • 2080
          +1 I have 3 351 w engines running DUI . Huge difference over points.
          • H2Oboomer
            • Jul 2021
            • 10
            • Claytor Lake
            I might have a solutiin to one problem now.
            I still need to buy a bracket that held the
            resistor.
            • H2Oboomer
              • Jul 2021
              • 10
              • Claytor Lake
              Im confused based on the model number
              on the engine tag vs the firing order
              in the manual..
              • hal2814
                • Jun 2016
                • 541
                • Ft Worth, TX
                Always trust your engine tag over anything else. That looks like a standard firing order for a left handed engine. You have a left-handed engine with a right handed prop accoring to the model number on your tag which is typical on an 89.
                • H2Oboomer
                  • Jul 2021
                  • 10
                  • Claytor Lake
                  Humm.. per tag and owners nanual this midel is Right
                  rotation..
                  • gun-driver
                    • Apr 2011
                    • 132
                    • Pittsburgh Pa
                    • 1985 Ski Nautique 2000 Sport Nautique
                    Read what it says at the top of the page of the manual that you posted right after the word IMPORTANT:
                    Then look at your ID plate again
