2017 g23 starting issue
  • gmustangt
    • Aug 2015
    • 25
    • Kelowna BC
    • 17 g23
    Having starting issues with 2017 g23 zz6.
    I assume there is a starter contact issue on the keypad
    - when powering up the boat electrically (blower) the start button works every time .
    - when pushing the start button it takes 15-20 pushes and some
    luck to get it started (engine on). Engine cranks right away and starts as soon as you get lucky.
    - boat has also randomly shut down the engine 2 times in the last 3 weeks while pulling a surfer. Electrical stayed all on , just engine completely died. Pushed the start button and engine fired right up.
    Why would the keypad start button work to power up the boat , but have issues getting it started ? Any ideas where to look?
  • nohlan_4
    • Jan 2016
    • 413
    • Canada
    • 2013 G23 450
    Do you turn your batteries completely off every time you put the boat away after use?
    You might not be waiting long enough in between when you turn them back to on then enter the code to start. Turn batteries on then wait at least 20 seconds before entering the code.
    If not that the could need a new key pad or loose connection on the back of the pad. Easy enough to check/replace.
    • gmustangt
      • Aug 2015
      • 25
      • Kelowna BC
      • 17 g23
      Yes batteries are always completely off.
      I can turn batteries on , put code in ,and power up the boat within 10 seconds . Then wait to start from there
      If the start button works every time to power up electrically , I would elimante that connection?
      or
      are there 2 contacts on the back ? One for power up and one for engine start?
      • tandcc
        • Jul 2018
        • 17
        • Hendersonville TN
        • Ski NAUTIQUE M235
        The owners manual for my 2019 says to wait 30 seconds after turning battery on before I enter the code.
        • DoubleUpDisaster
          • Feb 2020
          • 75
          • Southern WI
          • 2019 G21
          My 2014 says the same. There are some components (ECU and keypad, perhaps?) silently powering up and running self tests during the first little bit after 12v is applied. Make the battery switch the very first thing you do when you get to the boat. Then load your crew and gear before you put in your code to see if that alleviates the issue.
          • nohlan_4
            • Jan 2016
            • 413
            • Canada
            • 2013 G23 450
            or
            Yes 10 seconds isn’t long enough wait longer. I always wait 20secs at least and it seems to always be ok. But try the 30secs it says in the manual and see if that helps the issue.
            • gmustangt
              • Aug 2015
              • 25
              • Kelowna BC
              • 17 g23
              Ok re looking at the manual I see it asking for 30 seconds as you guys mentioned .
              Weird as it never acted this way before
              • nohlan_4
                • Jan 2016
                • 413
                • Canada
                • 2013 G23 450
                That’s the easy try first, then I’d be looking at new key pad or the connection on the back of it. It’s a multi wire plug so could be one connection not making properly.
                • 99bison
                  • Jul 2014
                  • 135
                  • Location
                  Original batteries?
                  Safety cord?
                  • gmustangt
                    • Aug 2015
                    • 25
                    • Kelowna BC
                    • 17 g23
                    Don’t think it’s the batteries , it doesn’t even attempt to turnover . But when you get lucky it starts like it’s new.
                    Originally thought it was the tether as first time it just died while surfing . But tether is on properly.
                    • 99bison
                      • Jul 2014
                      • 135
                      • Location
                      I’ve noticed when batter(ies) are low or are old and don’t hold a charge as well the push button to start will not respond or be really delayed, exactly as you are stating. It seems likely a computer decision saying voltage is lower than it needs to start.
                      Next time it happens look at the voltage if it’s sitting lower than normal at rest (for me 13+ V at rest it doesn’t happen), but if less than 13 at rest it starts to happen, and down to 12.3 or less it will likely happen.
                      • gmustangt
                        • Aug 2015
                        • 25
                        • Kelowna BC
                        • 17 g23
                        Ok , I’ll add it to the list to check.
                        anyone know if there’s a minimum voltage for the start button to engage the starter ? If so the V?
                        • Jamo89
                          • Aug 2024
                          • 1
                          • Vernon, BC
                          • 2017 G23
                          Did you ever end up getting this issue sorted? I have the exact same problem going on. Boat has died randomly a handful of times over the last 2 years - screen stays on when this happens. Also has a random no start issue that is the same as yours. I have new batteries, connections/main grounds are all good and when it does start it starts fine.
                          issue is intermittent so it is hard to diagnose when al is working fine.
                          • Scooter G
                            • Jan 2022
                            • 1320
                            • On a Lake in Idaho
                            • 2022 G23 ZZ8
                            Just a couple of cents on a revived thread that died in '21. I love these "Hey I need help", but I'm not going to let you know what I did to fix it threads.
                            We were having random intermittent no starts, and stalls earlier this season, maybe it started last season, all a blur.
                            I replaced the throttle base assembly, and not a single issue since then (knock on wood). FWIW
                            https://www.planetnautique.com/vb5/f...s-210-230-2015
