I am replacing all of my drain plugs in my 06 206 with ball valves and fittings for quick draining of my engine (330 HP) without the use of wrenches.
Can the Knock Sensor be mounted to a brass T fitting into the block with the ball valve tied into the down side of the T fitting?
This would eliminate removing the Knock Sensor to drain this side of the block.
Thanks in advance for any input.
Steven
Steven
