Having an issue with the bilge pumps on our GS 22. I read the previous posts and information in the manual on how the bilge pumps work and the various lights, but I still don't think they are working correctly.
Last weekend we took a wave over the bow after dropping a skier at the dock. It was two waves actually and it was quite a bit of water. I checked the bilge and it was over the bottom the bilge pump, so I expected the pumps to automatically kick on and drain it, but they didn't. I pushed the button to force them to run and they still didn't, though I did hear them cycle on for a second. Ultimately I had to put it on the lift and pull the drain plug.
The local dealer took a look this week and they are saying the pumps are working properly, however, I do not believe they went to the extent of adding water to the bilge and having it pump out.
I am wondering if whatever mechanism detects water is not working. I am assuming this is embedded in the actual pump. I did not see a separate float switch.
If this is user error, I think they have over complicated what should be a basic function of turning on the bilge pump manually.
