2016 G23 H6. Replaced a failed alternator, experienced loud chirp. I reset serp belt, checked all pulleys (confirmed smooth and tight), fired back up and there was knock seemingly coming from crank. Oil pressure is ~15 psi. Any suggestions on next diagnostic steps?
If its knocking with no belt there's internal issues and I would no longer run it until I figured out what it was. If oil pressure is that low then the pump is failing or something is stuck in the pickup screen. Stupid question but you checked the oil level right? Last oil change?
- Aug 2014
- 370
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
15 psi oil pressure while running a full engine load? I’m an old petrol head and the rule-of-thumb was 10 psi oil pressure per 1,000 RPMs. If you really are only running 15 psi then you may have a rod knock and an engine that’s about to implode.
JQ
Originally posted by Jonny Quest View Post15 psi oil pressure while running a full engine load? I’m an old petrol head and the rule-of-thumb was 10 psi oil pressure per 1,000 RPMs. If you really are only running 15 psi then you may have a rod knock and an engine that’s about to implode.
JQ
