Belt Issues on GS22
  • Devo77
    • Mar 2019
    • 39
    • Lake Keowee, SC
    • 2021 GS22
    Belt Issues on GS22
    We got a new 2021 GS22 earlier this season. After about 8 hours the belt started squeaking when first starting at low speeds. Once the engine warmed up the noise disappeared.
    But this was super annoying and Nautique refuses to address this under warranty as they claim it is a wear and tear issue (despite only having 8 hours on the boat). Dealer finally replaced the belt at 35 hours and the noise went away for a while. After putting another 10 hours on the boat the noise is back!!! Anyone else having similar issues.
  • tmb
    • Mar 2004
    • 616
    • Midwest
    • '22 GS 22 ‘12 200
    I have almost 40 hours on my 21 gs22 with no issues.
    '18 SAN 210 Reef Blue/Admiral Blue Metal Flake
    '12 SAN 210 TE Black/Masters Blue
    '09 SAN 210 TE Black/Fury Red
    '08 Air 216 TE
    '02 Air 216
    '98 Sport Nautique
    '89 MC Prostar 190
    • North Woody
      • Jun 2020
      • 143
      • Glencoe, IL
      • ‘20 Nautique GS22 1936 Chris Craft
      Sorry to hear that. FWIW, we've got 120 hours on our 2020 GS22 with no belt issues/engine noises of any sort. Other than a failed NSS actuator and a necessary software update to fix an audio issue, this boat has been pretty much bullet proof!
      • kylant
        • May 2010
        • 540
        • Lake Tahoe
        mine is the same. it is only on initial start-up and only lasts a few seconds
        • Devo77
          • Mar 2019
          • 39
          • Lake Keowee, SC
          • 2021 GS22
          Originally posted by North Woody View Post
          Sorry to hear that. FWIW, we've got 120 hours on our 2020 GS22 with no belt issues/engine noises of any sort. Other than a failed NNS actuator and a necessary software update to fix an audio issue, this boat has been pretty much bullet proof!
          Last year I put on 140hrs on 2019 GS22 - no issues with the belt.
          • fwd_loop
            • Jan 2007
            • 35
            • Muskoka
            • 2021 GS22 2007 211TE - Sold
            I have a 2021 GS22 and have recently noted the same issue - 36 hours of use so far. I first noticed it after 10 hours and it always appears on start up and then goes away once things have warmed up (after about 15 mins).
            I haven't taken it into the dealer yet, but am planning on, as its the type of noise that a brand new premium boat should not have this early in its life.
            2021 GS22 - Lovin every minute of it
            • XBIGPUN66
              • Oct 2012
              • 456
              • WI
              We had a similar issue with our 210 when there was water in the bilge it was getting in the belt. It would chirp for a bit and then go away. We make sure to pull the plug now after use.
              Ian S
              2014 SANTE. NSS. Pro balllast. Boatmate trailer
              2004 SANTE. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
              2009 Moomba Outback (prev). Boatmate trailer
              • GatorBaitWake
                • May 2016
                • 22
                • Miami, Florida
                • 2021 Super Air Nautique G25
                There must be water getting to the belt. It might be from too much water in the bilge or it could be coming in from above. Make sure your rear bilge is working properly. It may be clogged or dead. And then you will have to start searching for leaks coming from above. The rear compartment and engine hatch doors may need to be adjusted tighter so water doesn't get in through there. Or the drainage fittings and hoses may be leaking water onto the belt.
                • mzimmer75
                  • Mar 2006
                  • 35
                  • Saint Louis Park, MN
                  • 2020 Nautique 200
                  I’ve noticed some slight belt noise, or bearing noise, on my 2020 200. Always shortly after start up and up on plane at an easy cruise. It never lasts long. I’ve heard it four or five times. My wife even commented on it yesterday.
                  Definitely no water in the bilge getting on the belt.
                  I’ll be interested to hear if anyone comes up with a firm cause and fix.
                  18 hours on my boat.
                  • ESP
                    • Feb 2021
                    • 25
                    • Regina Saskatchewan Cananda
                    • 2020 GS22
                    Have same boat and had a similar issue loose bolts on the 4 bolts on the heat exchanger there was a drip when cold putting anti freeze on the belt, snugged up the bolts removed and washed the belt in dish detergent and cleaned the pulleys squeak is gone. The leak was very slight and never noticed the anti freeze level dropping
                    • ESP
                      • Feb 2021
                      • 25
                      • 2020 GS22
                      Here is the culprit
                      • mikenbike211
                        • Sep 2016
                        • 447
                        • New York
                        • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
                        the thermostat was making the belt squeak? how?
                        • kylant
                          • May 2010
                          • 540
                          • Lake Tahoe
                          • ESP
                            • Feb 2021
                            • 25
                            • 2020 GS22
                            • mcosub
                              • Aug 2016
                              • 235
                              • Orlando
                              • 2020 GS22 2017 SANTE 210
                              had the same issue on my GS 22. They swapped the belt twice to get rid of the noise and they also said it could have been coming from the water pump. Not sure if that was it or not but it was fixed 20 or so hours ago and the noise hasnt come back. We are almost at 100 hours.
