Ran out of gas - will it start after adding new gas and should I expect any damage?
  • uwhusky
    • Aug 2006
    • 320
    • Salt Lake City
    • 2015 SANTE 210 w/PCM 450hp engine
    I was out over the weekend and ran out of gas. I have a 2015 SANTE 210 with 450 PCM engine. Luckily I was near the ramp so we were able to get it out and onto the trailer fairly easily.
    Did I do any damage to the engine or full pump?
    Should I just fill it and go out again or would I be better off attaching a "fake lake" in the driveway after filling it to be sure?
  • Stevemo14
    • Apr 2019
    • 691
    • Columbus, OH
    Not sure about a 2015, but I think you should be ok. I have run out in my 05 and no issues.
    just make sure you cycle the ignition a few times till the fuel pump is primed again and I would think you should be good to go.
    • shag
      • 2217
      You shouldn't have an issue. I would be more worried about the possibility of sucking up any junk that was in the bottom of the tank... Maybe the fuel pick ups are a little higher to prevent that... Not sure... I would just fill her up and go.. Easy at first just idling for a bit at the dock to be sure.
      • uwhusky
        • Aug 2006
        • 320
        • Salt Lake City
        shag Stevemo14 Thanks!
