95 Super Sport 351 missing like it's on rev limiter??
  • ricoshred
    • Sep 2003
    • 25
    95 super sport misses like it's on the rev limiter. It seems to run ok after an hour. I put some fuel dry in, it didn't help?? Plug wires look good it think. Any thoughts??
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: 95 Super Sport 351 missing like it
    What engine? What rpm? Are your plugs good? have you tested the plug wires? How old is your carb? Has it ever been rebuilt? (That is if it is carburated).
    Hook the fake-a-lake up or something and run the engine at the rpm where it cuts out... and one by one pull A plug wire off of the spark plug, then replace it. You can find if it's 1 particular cylinder that's messing up or a combination of a few or another un related problem.
    Also could be an ignition problem. Electronic ignition or the old points and condenser? Probably electronic...
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • ricoshred
      • Sep 2003
      • 25
      Its fuel injection
      Its fuel injected style.
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        RE: Its fuel injection
        At least test the wires and put new plugs in it. Drain the fuel and put fresh fuel in it, or run all the fuel out then see what happens.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2000 SAN
        • ricoshred
          • Sep 2003
          • 25
          purin like a kitten
          It's amazing what pluge cap & rotor will do. I also replaced 2 bad plug wires with some I had laying around the garage. Does any one know what's the best option for wires??
          • DavidF
            • Sep 2004
            • 611
            • Austin, TX
            RE: purin like a kitten
            PCM from CC for the plug wires due to customized length for PCM engine. Or, you can order or make your own to match existing lengths.
            • surroundsound64
              • Jul 2005
              • 2147
              • Longview, TX
              I got mine at the autoparts store. Autozone I think. Just a universal kit. You'll have to play around with the different lengths though. But for $7, it's worth it. Plug wires don't have to be "marine grade". All plug wires have to be anti-spark or it would defeat the purpose of the wire.
              2018 SAN 230
              1981 Ski Nautique
              Sold - 2000 SAN
