I made a post a few days again about this but issues are different and no replies in the other for a few days.
Boat will crank, not start.
so far, I have replaced a battery (one tested bad)(27DC from autzone) seems like it should be fine.. It is a deep cycle but has 840 MCA.
Also had to replace the negative battery terminal on it because overtightened and cracked the old one. Spark plugs (were just old so needed to replace anyway)
I also replaced the low pressure pump (no fuel in fcc) and fcc fuel filter. I now have 36 PSI on the fuel rail. Thought this was the issue. Apparently not. Is it safe to assume it's not fuel related because I have 36 psi on rail?
Already have the two relays on order even though they appear to functioning properly.
one odd thing is it started fine twice in the garage about a week ago but when brought to water would not start even after bringing it back out of water. Since then I have not been able to start it.
I have tested ignition with a inline tester but honestly I don't know what it's supposed to look like. However it does light up and seems to be functioning.
Any ideas on what I should looking for?
