Using SCWake recommended sea deck cleaner. Says to rinse after cleaning/scrubbing. Do I just turn on the ballast and use a hose, let it return to bilge?
Yea. If the boat is out of the water you can let it drain through the plug hole. Mine is on a lift and out of the water, but I still let the bilge pumps push it out. I do this to ensure they're working properly and to let them push some soapy water through the pumps. Cleans them out a bit.
-Charles
Hopefully they recommended Dek Magic. That's SeaDek's official cleaning product.
Be sure to rinse well! I took a BAD fall from the top of the engine down to the water, hitting the steps and the platform on the way down. Bruised two ribs. That hurt! My fault though. I should have rinsed better than I did.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
We use dr bronner's for the seadek in our 210
Ian S
No, that's SC Wake's own product, not the official SeaDek cleaner.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
So, I was bothered with how I got there... On this page: https://scwake.com/boat-juice/
And on this page:https://scwake.com/why-boat-juice-th...c-wake-seadek/
It says, "SC Wake Boat Juice, The Official EVA Foam Cleaner"
Even the URL says official EVA foam cleader seadek
Guess I was just hoodwinked.
Originally posted by FoodClub View PostGuess I was just hoodwinked.[/B]
The SC Wake Boat Juice you linked.
The "other" Boat Juice.
FWIW, I have some DekMagic and it's good cleaner. It cleaned a spot of grease that Simple Green, Dawn and Babe's Seat Soap couldn't remove. I don't know how it compares to the SC Wake stuff.
