I just replaced the port water sending unit and pump. The tank was about half full and drained fine. Tank will not fill, I do notice bubbling water coming from the underside of boat when attempting to fill. Any thoughts? Thanks in advance.
Are you sure you didn't install it backwards? Sounds like it is trying to empty when you want to fill. Could be installed backwards, or the wiring could be reversed.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
