Hi all, I bought a 94 Ski Nautique last fall knowing that the PCM EFI was first-generation and no longer supported by PCM. It runs very rich, and have been told that not much can be done about it. It accelerates very well, but hesitates at maybe 1200 to 1500rpm but then the power surges smoothly after that. The timing was set at 16 deg and my mechanic brought it down to10 deg because he thought it would help the hesitation; this was not helpful as now I still have the hesitation but lack power both before and after the hesitation. We exclusively use the boat for course skiing and want as much power as is practical. The boat has 330hrs after reportedly having the block cracked from freezing, total boat hours supposed to be around 650.
My questions are:
1. Is there a good after-market throttle body fuel injection system that I could install, or could I put a newer PCM system on? My mechanic is skeptical of after-market EFI as he has not had good experience with them for cars.
2. Should I just put a 4bbl Holly on it and be done?
3. Where can I find an engine specification sheet? I'd like to check the compression before I spend some money on this.
Thanks - anything helps!
My questions are:
