Hi,
Just seeing if anyone has considered one of the alternate ECM gateways on the market. From a quick look at these , it appears they plug into most ECM modules and convert the data to a NMEA data signal. From this conversion any MFD can be used to display engine information. Faria also do a range of digital gauges that are similar to the SAN gauges with a digital LCD screen read out and analogue style display that may be used.
A few links below for reference. It seems this could be a alternative at a reasonable cost that would closely replicate the original format of the early 2000's boats.
Fox Marine Gateway.
https://fox-marine.com/index.php?rou...tegory&path=81
Faria MG3000
https://fariabeede.com/2-pages/prod_...Gauge=2_mg3000
You tube install
https://www.youtube.com/watch?v=OldAiFfNYg4
Interested to see if anyone has tried this approach to resolve the dead gateway / gauges issue.
Fox Marine Gateway.
Faria MG3000
You tube install
