Anyone have any tips for breaking loose the 1/2” plug in the v drive? Squirted with penetrant, using a 1/2” socket drive and it won’t budge. Thanks!
I had a stuck one in one of my boats. I realized though that since I sucked in rv anti-freeze thru the system there was no way it could have water in it.
That being said, the only advice I would have would be to get some extensions and maybe get to a spot where you can get a breaker bar, and/or a piece of pipe over the ratchet.
I would try some heating
Ian S
I used a 12" drive, 3' long breaker with I believe a 3" extension on it to clear the end of the vDrive. The hardest part was supporting the bottom of the breaker to keep it from moving. Mine started to move after about 3 bumps. Another thought depending on room might be a 1/2" universal joint with an extension and a impact gun.
Soak it in PB Blaster? Rarely do I give kudos to a product...but that stuff works.
Maybe this will help....https://www.youtube.com/watch?v=hxFA08qRSoYLast edited by SilentSeven; 09-27-2021, 11:14 PM.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
Originally posted by relake View PostI cannot get it to budge at all, heated it, etc….any idea how much water is held in there?
The first year I had my boat it was stubborn so I used a breaker bar and extension. I propped the extension up on a block to help keep it stable. I did hit it with PB blaster every few hours starting a day or so before.
