* before you begin be sure to remove the driver side black partitions with the top rail and the pieces below to get access to the side of the engine. It’s a hassle but a must. I took a white grease pencil to mark my partition boards front back etc. so I can figure out which way they go back together lol
1. Unbolt drivers side exhaust riser - 4 bolts
2. Loosen 2 hose clamps at muffler
3. Twist and remove drivers exhaust off muffler w exhaust riser attached
4.15 mm and a breaker bar to loosen and remove serpentine belt
4b. Remove the hose clamps and the two black waterlines from the top of the water pump
5. Push back muffler and wedge a 2x4 between the red water pump and muffler to give yourself a little room to work on the pillar bolts.
6. 10 mm socket and a short extension to remove the three impeller bolts behind the pulley
7. Slide the impeller pump housing off the shaft and remove in the boat
8. Swap out the O-rings on each of the bolts and replace the O-ring seal that sits in the pump housing!!
9 remove the old impeller from the engine housing by twisting it a little and pulling it out with needle nose.
10. Work the new impeller into the pump housing on the engine by twisting it and working it in by pressing in to get it seated
11. With the new O-ring seals on the bolts twist the pulley as you seat the assembly back together on the engine get it pretty close and then you can finger start a 10 mm bolts on the pump housing
12. Tighten the bolts back down with either a flexible extension or a short extension and torque the 3 10mm bolts to 9 pounds each
13. Remove the piece of wood wedged between the muffler and water pump, reinstall the serpentine belt, reinstall the exhaust.
You may need to have a new exhaust riser gasket to install if your old one is cracked and crumbling. Torque before exhaust riser bolts to 15 foot pounds and finish at 25 foot pounds after you’ve been able to run the boat for a few minutes
It seems a little goofy to have to move the exhaust on one side. But that’s the only way I found to get any room to work on the impeller housing. people say I should be able to slide it off with the exhaust doesn’t seem to ever want to come off the riser so it’s easier just take the riser off with the four bolts to work
2006 SANTE - Bull in a China Shop - Central IL
