226 Dual Battery Switch
  • clsimmon
    • Apr 2017
    • 11
    • Austin
    • 2006 Nautique 226 LE
    Hi, could someone shoot me a picture of a factory installed dual battery switch on a 2006 or newer Nautique 226? We have the Limited version which did not come with the dual batteries or switch and would like to add it. We do however have the pocket for the the battery under the back seat as the Team version does. Thanks in advance!
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    There are 2 basic types of switch. OFF/1/1+2/2 and the OFF/ON/COMBINE (paired with an ACR).
    • distinguishedmotorsports
      • Aug 2016
      • 482
      • Austin, TX
      recommend blue sea #9002E which is the newer upgraded of the four position (on, off, on, combine) that has an alternator field disconnect. this makes the system fool proof. but the old fashioned #9002 will work, as would a 5511e if you want slightly less control or prefer the dedicated start and house batteries.
      • clsimmon
        • Apr 2017
        • 11
        • Austin
        Thanks for the responses. Do you guys have pictures of your switches? I need to see where Nautique is even putting these switches from the factory.
