I am winterizing my ballast tanks on a 2006 SAN . I am using a hose and a funnel to put the antifreeze into the ballast vent tank. None of the liquid is going into the tank it just keeps leaking out the vent. I did it last year so im not to sure what i am doing wrong. Any help would be appreciated. ty!
Sounds like either a blockage or too much of a drop in the hose. Mine drops down beside the tank before going up to the through hull fitting. Try disconnecting the vent hose on the inside of the through hull fitting and pouring it in there. I had to lift the hose up while pouring to get a good flow into the tank. Hope that helps.
