I'm sure there is a write up like this, some where, but all I could find are bits and pieces of this or that related to this subject. Like me, I bet there are many GT40 owners out there and as I learned, just putting in fuel stabilizer or changing the fuel filters, isn't enough. I'm working through fixing and updating the GT40 fuel system in my 1999 Air Nautique.
My story begins back on Thanksgiving eve when I took the boat out. I was cruising along, 2500 RPM, calm water. About a mile or 2 from the ramp, all of the sudden, the engine stalled. Surprised, I checked all the obvious things which resulted in a tow back to the ramp. I got the boat home, removed the engine cowling, rear seat bottom and back, and the removable floor panel, tank tie down hardware, etc, now what?
I'm starting at the fuel tank. The fuel supply and fuel return fittings on the top of the tank are aluminum elbows. The tank side is 3/8" male NPT and the hose side is 1/4 female NPT. Connected to the elbows are two straight brass fittings 1/4" male NPT to 3/8" hose barb. The hose barb fitting on the fuel supply elbow is different though, it's called an Anti Siphon Valve (ASV).
Being familiar with check valves per-say, it seemed to me that the ASV could be stuck (years of Ethanol, gummed up, bugs, etc.) on the seat keeping fuel from getting to the low pressure fuel pump (LPFP). I tried to remove the ASV and it is not budging, not without breaking something, so I broke it. Who remembers what dissimilar metals do. Well the ASV is brass threaded to an aluminum elbow on the tank, not good 20+ years later when you want to take them apart.
So now I need to replace the ASV *and* the elbow. One thing at a time, need to find a new ASV. Turns out there *is* an aluminum and brass ASV available. After my fun removing my old ASV, I figured I'd opt for the aluminum one, but..... research revealed the ASV is calibrated, what!
I found...
- Aluminum ASV is for 200 HP or less
- Brass ASV is used for 200 HP or more
My original ASV is brass and the GT40 produces >200HP, so that makes sense, I guess (even though dissimilar metals is not optimal). What does the metal have to do with it? I could see one having more spring tension than the other. Maybe the brass version has a stiffer spring for high suction pumps vs the aluminum, I don't know.
If found something on CCF that resembles the +/- 200HP calibration phenomenon, but not based on type of metal...
- 15 (WC) calibrated ASV equals .541 PSI or 27.99 mm HG of mercury
- 30 (WC) calibrated ASV equals 1.083 PSI or 55.99 mm HG of mercury
(I think WC means water column. Imagine a vertical tube, one 15 inches and the other 30 inches)
Industry standard regarding use:
- 201 HP Engine and Higher = 15 calibrated ASV
- 200 HP Engine and Less = 30 calibrated ASV
Then I found this on another site selling the ASV...nothing about type of metal or HP...
Features 15 calibration yields 15 in. vertical height protection.
Features 30 calibration yields 30 in. vertical height protection.
This makes more sense to me. The ASV is calibrated for the height difference between the ASV and the potential for a leak (rubber fuel line in the bilge splits open). So if the fuel line dips below the ASV, like it does in my boat, gravity is pulling on the fuel, trying to overcome the spring tension in the ASV. And the spring tension must be light enough for the LPFP to open the ASV and strong enough so the fuel in the fuel line can't open the ASV, tricky balance.
When I search the various vendors for a new ASV, I can find brass and aluminum. Attwood and Moeller do have 15 or 30 (usually etched on the fitting). SKIDIM and WL (who I expect to know this stuff) both sell the aluminum and brass fitting, but no mention of 15 or 30, let alone which one we need to use. Maybe it doesn't matter at all, just use what ever. I do know the USCG requires the ASV and I'm sure my insurance company won't be happy if I remove it. A final concern is if I choose wrong, one that needs more vacuum to unseat the ball in the ASV, what will that do to my LPFP? Can it cause fuel starvation issues?
So, the question is, what do I need to buy?
-Scott
Next up.... the fuel pickup tube.
I found...
-Scott
