Fresh Air Exhaust
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    Fresh Air Exhaust
    I have a 2011 sport 200v. I am looking to get a fresh air exhaust. Anyone installed the fresh air exhaust on a single outlet? What’s the difference (advantage/disadvantage) between through hull and using the existing outlet?
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Great choice in this upgrade, to answer your questions the advantages of the thru hull is much cleaner look and more sturdy and robust, Disadvantage would be little more labor intensive for the install.
    Advantages of the non-thru hull fresh air is easier to install. Disadvantages would be aesthetics because you have to use braces that mount to the swim platform brackets. It works fine just not as clean looking as the thru-hull.
    both work the same, one just looks better but takes a little more work to get it installed. I have done both and my vote is thru-hull all day
    1989 Sport Nautique
    • shag
      • 2217
      One of theist upgrades I have done... I don't think the thru hull was available when I did mine years ago - but I would've probably dome the thru hull for the reason mentioned above. Either way, quieter while idling around, noticeable less exhaust gasses, and no affect on wake or wave at all.
      • Lakejackson
        • May 2012
        • 160
        • Lake
        • 2011 Sport 200
        Did either of you get the flapper option?
        • ScooterMcgavin
          • 1478
          • 2014 SAN 210 TE
          No I didn’t get the flapper option on my FAE and the Factory Nautique one I installed on my 14 didn’t have a flapper either
          1989 Sport Nautique
          • shag
            • 2217
            No flapper
            • amaaraba
              • Aug 2020
              • 24
              • Minnesota
              I have a 2012 200v and installed the non thru hull with flapper last winter. It takes about 2 hours and you need a second person to help with getting the u ring unscrewed. That was the most difficult part for me.
