ballast gauge stuck on full?
  • khaz
    • Sep 2006
    • 30
    • San Diego
    The factory ballast gauge on my '01SAN is stuck on full. Does anyone have any suggestions how to get this working. I have tried to stomp on the top of the tank (dealer's suggestion), but it has not worked yet.
    Kevin
  • richard
    • Feb 2005
    • 406
    • HK
    RE: ballast gauge stuck on full?
    May be you have a bad water level sensor,disconnect one cable of the ballast tank sensor,if the pointer will go back to 0 or you have a bad guage.
    • khaz
      • Sep 2006
      • 30
      • San Diego
      Thank you, I will look into the sensor. The other side was stuck on empty, and clubmyke drove the boat around and was able to free it up for me. After leaving the lake last weekend the port side would not show empty. I am not sure if there is a way of freeing this one if it is in fact stuck on full.
      Kevin
      • clubmyke
        • Sep 2004
        • 414
        • so cal
        sounds like a sticky sensor... did you make it out today ? it was nice... one of the nicest days and i got stuck at home..
        • richard
          • Feb 2005
          • 406
          • HK
          Ballast sensor
          I experienced broken a gap in the ballast sensor so water go inside and corrosive the PCB,this cause the sensor open circuit,so the sensor pointer will stay with 0.
          • khaz
            • Sep 2006
            • 30
            • San Diego
            Mike, I am thinking it is just sticky also, but how can I get it down. I understand how the other was able to move, as you got the water rushing in, it must have jarred it loose. If it is stuck at the top, what is going to make it shake loose?
            We were not able to make it out yesterday either, the crew going with us was not feeling well.
            Kevin
            • richard
              • Feb 2005
              • 406
              • HK
              Ballast sensor problem
              khaz:khaz:
              Cut one wire of the pair wire of ballast sensor near the sensor on the ballast tank, (there is a joint), the pointer of the guage will fall to 0,(if the sensor is shorted).vise versa, short the two wire of th sensor the guage will jump to full,( if the sensor is open),the photos shows a good sensor, and a bad sensor caused by water leak and i'm going to remake the reed switch sensor PCB inside the tube.
              • clubmyke
                • Sep 2004
                • 414
                • so cal
                after reading richards post... i would just replace it... it cant be that much money..
                • richard
                  • Feb 2005
                  • 406
                  • HK
                  where can get new ballast sensor
                  Yes, it's not easy to make a sensor,even I'm an electronic eng.since the damaged sensor is too bad to follow, If I know where can get a new one, I would rather to change a new one.
                  • coloradonautique
                    • Sep 2006
                    • 98
                    • Denver, Colorado
                    • 2001 AN 1990 SNCB
                    RE: where can get new ballast sensor
                    Ditto, I have a flaky port side ballast sensor on our '01 AIR. If someone finds a source and price for these, please post.
                    ___________________
                    2001 Air <-- New boat
                    1991 Ski <-- Old boat
                    Denver, CO
                    • clubmyke
                      • Sep 2004
                      • 414
                      • so cal
                      any dealer should have them or order it for you..
                      • richard
                        • Feb 2005
                        • 406
                        • HK
                        My dealer nnnn.., is the only dealer in my area, but I feel very hesitate to call .
                        • richard
                          • Feb 2005
                          • 406
                          • HK
                          • khaz
                            • Sep 2006
                            • 30
                            • San Diego
                            I talked to a mechanic, and he sent me to www.wemausa.com. He suggested that I go with the stainless steel ones, since they will last longer. They are model SSS, $40 each on this site. My boat calls for the 6" sensors. I hope this helps.
                            Kevin
