Was using the boat this weekend, when I noticed water coming into the main passenger area from the rear left corner of the boat. (not a major flow, but a small stream on top of the carpet) I popped the rear storage compartment, and there were two wet spots in there, but I could not see any water sources?
I hit the bilge pump, and it dumped quite a bit out. Thus, I started looking for other issues.
The carpet in the bow of the boat was also wet.
While running the engine with the cover open, I could not see any water leaks. Also, the driveshaft seal appears to be fine.
Any ideas on the cause(s)? I'm thinking the front water could be from the heater?
