GT40 engine miss at all RPM
  • kend
    • Oct 2013
    • 193
    • DFW, Texas
    • current 2001 Air Nautique previous 1988 Sanger DX
    The miss started last year but is getting worse. 2001 GT40 fuel injected
    Cranks right up when cold or hot, but has to turn a few seconds if just warm. It has just a slight miss at idle. When you give it gas the miss becomes more apparent but the RPM will still climb to over 4k and the boat will go 45mph. At 4k RPM you hear a quick blip every .75sec
    The miss gets faster at high RPM but feels more time based than a bad cylinder
    I replaced the spark plugs last year and looked at them this week, they all look even and clean. Cap & rotor are 2yrs old but look clean.
    I'm planning on replacing the TFI module tonight (kind of just a guess)
    Has anyone had this issue?
    Ken
    2001 DD Air GT40
  • gun-driver
    • Apr 2011
    • 132
    • Pittsburgh Pa
    • 1985 Ski Nautique 2000 Sport Nautique
    Check your exhaust manifold gaskets for a leak.
    • kend
      • Oct 2013
      • 193
      • DFW, Texas
      Is the idea that it would drip water on the plugs?
      Ken
      2001 DD Air GT40
      • ESP
        • Feb 2021
        • 25
        • Regina Saskatchewan Cananda
        • 2020 GS22
        Compression, plugs for cracks, wires, take a magnifying glass take a good look at the rotor for cracks in the cap, a couple ozs of sudsy ammonia in 8 oz of water and spray the wires if you have a wire shorting the spark will follow the ammonia like a lightning bolt. Not likely a module or coil, if it fires right up.
        • kend
          • Oct 2013
          • 193
          • DFW, Texas
          I've never heard of this but I have been wondering if the wires are ok; they have been replaced by previous owner with nice 8mm (except coil wire). Searching I found multimeter/ohm tests and a guy spraying just plain water in the dark....but ammonia...sounds dangerous. I'll try it tonight.
          Also replacing coil wire and installing TFI module & lake testing today.
          Ken
          2001 DD Air GT40
          • charlesml3
            • Jan 2008
            • 2454
            • Lake Gaston, NC
            • 2022 G23
            Replace the cap & rotor and all of the plug wires. It's a cheap test and probably something that needs to be done anyway.
            This is an ignition problem almost for sure. Eliminate this first.
            -Charles
            • gun-driver
              • Apr 2011
              • 132
              • Pittsburgh Pa
              Can you actually feel the miss in the performance or is it more of a sound?
              • kend
                • Oct 2013
                • 193
                • DFW, Texas
                just a sound most of the time, but when you take off from idle you can feel it
                Ken
                2001 DD Air GT40
                • Jonny Quest
                  • Aug 2014
                  • 384
                  If not the Thick Film Ignition module, then I would look at injectors…
                  JQ
                  • gun-driver
                    • Apr 2011
                    • 132
                    • Pittsburgh Pa
                    A leaking exhaust gasket can make a ticking sound like a miss, that’s why I suggested it earlier. I would rule that out before throwing more parts at it.
                    If you can really feel it then I would as suggested above check for a arcing spark plug wire then possibly replace the cap and rotor as they are cheap.
                    I would think it’s ignition more than a fuel delivery issue at this point.
                    The feel of a miss during acceleration from idle could be a drive line vibration from the prop or alignment.
                    • kend
                      • Oct 2013
                      • 193
                      • DFW, Texas
                      Just got back from lake test and it runs like new. I replaced the TFI and the coil to distributer wire...so not sure which did the trick. I'll keep the other plug wires, cap, rotor for a rainy day.
                      Ken
                      2001 DD Air GT40
                      • gun-driver
                        • Apr 2011
                        • 132
                        • Pittsburgh Pa
                        Glad she's running like a champ again
                        If you wanted to see which did it throw the old coil wire back on it, you may have a spare TFI also.
