Heater Blower Probs
  • MN Ryan
    • Aug 2020
    • 1261
    • Maple Grove, MN
    • 2007 SV-211 TE
    Heater Blower Probs
    Hello,
    '07 SV211 Team Edition. I finally got it in the water yesterday and noticed a new problem with the heater. Normally, you press the button on the keypad once for low, twice for medium, and 3x for high. Now, it only goes on and off, and it only seems to be low speed.
    It is blowing warm air, and everything else is working as it should.
    Anyone ever experienced this before? My wife and daughter will be sad!
  • 03SANTE
    • Sep 2018
    • 166
    • PA
    • 2003 SANTE
    I have a 2003 210 so this is a shot in the dark, but I do have the same single switch functions for the three speeds... My heater blower motor never worked since I took ownership and my winter project was to replace it. After replacing the blower motor, I pushed the button to test it out but it would only run on one speed. Frustrated for sure, I checked the fuse panel and I believe there were two separate fuses(breakers?) for the different fan speeds. Fortunately, one had tripped so I reset it and all three speeds came back and it works great now.
    • MN Ryan
      • Aug 2020
      • 1261
      • Maple Grove, MN
      • 2007 SV-211 TE
      Ooh, that would be a nice fix. I'll check into it.
      • 03SANTE
        • Sep 2018
        • 166
        • PA
        • 2003 SANTE
        Found pic online. One breaker says heater med/high the other says heater low. Hopefully yours the same and that's all it is. Good luck!
        • MN Ryan
          • Aug 2020
          • 1261
          • Maple Grove, MN
          • 2007 SV-211 TE
          That panel looks very similar to the one under my helm. I will have to check it out.
          • MN Ryan
            • Aug 2020
            • 1261
            • Maple Grove, MN
            • 2007 SV-211 TE
            OMG, 03SANTE, thank you so much. You nailed it!!! I love easy fixes.
            • bturner
              • Jun 2019
              • 1576
              • MI
              • 2016 200 Sport Nautique
              Glad to see this fixed your problem and thanks for posting the fix. Next question would be..... why did it pop the breaker. Hopefully it was just sticky running the first time in the season.
              • MN Ryan
                • Aug 2020
                • 1261
                • Maple Grove, MN
                • 2007 SV-211 TE
                Yeah, I'm not sure. It didn't run and then pop the breaker. I did have to pull that panel off to install the PP StarGazer upgrade this spring, so I'm thinking I maybe tripped the breaker in the process. Or maybe the dealer did it when they winterized it last fall--it worked just fine before I had it winterized. I ran it on high for a few minutes in the driveway last night. I guess all I can do is keep an eye on it.
                • 03SANTE
                  • Sep 2018
                  • 166
                  • PA
                  • 2003 SANTE
                  Glad to hear it worked and happy to help someone else as I am a long time recipient of help on this forum. Weird thing is I am currently between projects and haven't checked in for months then I saw your post when I did. Go figure?
                  • MN Ryan
                    • Aug 2020
                    • 1261
                    • Maple Grove, MN
                    • 2007 SV-211 TE
                    It was meant to be!
                    • MN Ryan
                      • Aug 2020
                      • 1261
                      • Maple Grove, MN
                      • 2007 SV-211 TE
                      I ran the heater on high for about 20 minutes yesterday with no issues.
