Onboard Charger
  • Klipper
    • Jun 2018
    • 38
    • Muskoka, Ontario, Canada
    • 2018 SAN 230
    Onboard Charger
    Hello,
    2018 SAN 230 with onboard battery charger and 2 batteries. When I use the onboard charger, only battery 1 gets charged, battery 2 does not charge. I found this problem after taking it out of storage and only one battery had voltage. I had plugged in the battery charger during storage.
    Has anyone else had this problem? Any recommendations? I have tried switching the battery switch to "1+2" thinking they may have to both be "on" to get the charge but no change.
    Any help would be greatly appreciated.
    Thanks.
  • MN Ryan
    • Aug 2020
    • 1395
    • Maple Grove, MN
    • 2007 SV-211 TE
    What kind of charger?
    There should be fuses on the leads for the charger. Locate and check them. It is also definitely possible that one of the banks of your charger died.
    Are there lights to indcate charging status, etc? Are they functioning?
    • Klipper
      • Jun 2018
      • 38
      • 2018 SAN 230
      The charger is a ProMariner ProSport 12. All the indications show charging, but there are no separate indicators for each bank…
