I'm getting a little bit of chatter when getting up on plane while towing, noticed it more with heavier pulls. Any advice on what to evaluate/adjust would be much appreciated! Thanks
Very likely you have a slight bend in a prop blade or two. You may not even be able to see it. I suggest having the prop refinished and balanced by a reputable repair shop.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I had some chatter in the wheel when pulling a surfer out of the water. Mine was not an out of balance prop. Dealer said to put a few hose clamps around the steering cable, I guess to add a little resistance to the cable and dampen the chatter. That worked to stop the chatter. But, also, a few weeks later I found my rudder packing was loose and leaking a bit (just drops). I could see that also causing chatter, if the rudder could move a little more than it should in the packing. I adjusted the packing nut to stop the leak.
You might first check your rudder packing, and if it's good, try the hose clamp trick. Bother are cheaper than a new prop.Last edited by g_force; 05-31-2022, 07:38 AM.
